Hot Fuse in water heater spur | on ElectriciansForums
Discuss Hot Fuse in water heater spur in the UK Electrical Forum area at ElectriciansForums.net
M
mk1rob
Hi guys
Just been to a job where they had a 2.75-3kW under sink water heater on a plug and socket. The live in the plug had melted. I changed this arrangement for a switched fused spur treating it as if it was a standard immersion heater making sure all connections are tight as i thought this was probably the problem in the first place..
Its a 16A radial in 2.5mm twin & earth with 1.5mm flex from the spur to the heater. Circuit is approx. 3m long.
Ive switched the spur on and let the water heat up and switch off via the thermostat and noticed the fuse in the S/F/spur is still getting hot.
Any ideas on what may be causing this? Thanks in advance.
Reply to Hot Fuse in water heater spur in the UK Electrical Forum area at ElectriciansForums.net
There's some stunning Chinglish on that data plate
    • Optimistic
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
