Guest viewing is limited
W
wolfiehogan
hi guys
if an electric shower keeps changing from hot to cold, whats wrong??.
its a new shower only in about 6 months.
not much point debating as you don't know what a 'pumped electric' shower is but anyway -
if the stat is cycling you would check head and inlet filter among other things
your link is irrelevant btw
Spend hours and hours guessing, change all the inards cost a fortune and still doesnt work. Get another shower cut your losses, replaced in 30 minutes...........game over.
what about a call to the manufacture mate if it`s only 6 months old. some of them are quite helpful onn the tech lines
yeah will try that, but will they charge a call out fee if the problem is not within the shower, i.e water pressure. might get a plumber the check that out first
thanks
hot to cold
Australia
wolfiehogan,
wolfiehogan,
