P
pzool
I am buying myself a hot tub which requires a 6mm/32 amp service. I have a garage unit which has a spare to fit this extra supply to (no problem). i have measured the diameter of the cores on the SWA cable running from the weatherproof junction box outside of my house to the garage and the flat TW&E cable running from the circuit board to the same weatherproof junction box, this measures 2.5mm!
As the tub requires 6mm, i must presume that i need to update the 2.5mm SWA and Flat TW&E to 6mm. if so though the SWA would be easy to replace, how about the cable from the circuit board to the junction box? has anyone known to sucessfully disconnect both ends and pull a new cable through with the new one attached??
To be fair the cable coming from the circuit board would be doing an 's' shape?? not too sure whether to give this a tug hoping this will pull through or the other option is to put a new cable in a route all the way around my house - not ideal.
If anything please confirm that i am required to upgrade to 6mm, any suggestions please - thank you.
