View the thread, titled "Hot tub supply" which is posted in UK Electrical Forum on Electricians Forums.
Looks TNC-S from the picture. Also supply is looped?
OP Any reason for the CT Clamp on the tails? Is it because it is a looped supply?
If you are thinking of adding anything later you might want to look into getting un looped whilst you are doing this work.
You have a 60A supply so you will probably be ok if the hot tub definitely isn't an addition to the shower (with what loads are showing in the picture). Otherwise you may need an upgrade and to do that most certainly you will need unlooping.
The CT clamp makes me think there is some sort of throttling going on but then again it doesn't look like you have much connected? 4 circuits and the Shower? Storage Heaters are out but even if they were in you would discount them for Maximum Demand as they would be on over night.
The rating of your proposed hot tub will have a bearing on all the above.
Where is the hot tub going to be located ?
Does the manufacture say anything with regard to earthing.
I know some insist on tt others just make a statement on instruction manual all works to be carried out in accordance with the latest bs7671 wiring regs etc.
It’s going on my patio at the back of the house, I’m in the process of having the garage shortened to come into line with the back of the house. The car doesn’t fit in it so it’s just storage really. I haven’t got the hot tub yet, we’re looking at some the weekend.
The stipulation by some manufacturers in having to have a TT supply can make it very difficult to comply.
Where there is metal work connected to the pme in proximity, for instance.
I agree.plus if the tub is close to proximity of house driving down a rod could lead to problems to say the least
Ask the question again AFTER you’ve decided on which hot tub you are buying.
Some come with a 13A plug… a lot don’t.
If you are getting an electrician in to do the work, they may insist on running a new cable right back to board anyway.
One less joint is one less point of failure….
Reply to the thread, titled "Hot tub supply" which is posted in UK Electrical Forum on Electricians Forums.
West Midlands
United Kingdom
Hot tub supply
Paul K,
littlespark,
