Hot tubs.... | on ElectriciansForums
Discuss Hot tubs.... in the UK Electrical Forum area at ElectriciansForums.net
keniff
east sussex
So hot tubs, would you use the pme supply and get that slight tingle when getting out or rod it? Can't find a reg on it so it's a bit unclear. Your thoughts please!! :)
All depends on the installation, cable run etc and manufacturers instructions. Seen quite a few hot tubs but no stakes in.
I've just done a big swim spa on a three phase pme connection,
The regs state that if it's pme then it requires an earth rod with a resistance of 20 ohms or less .its tucked away in the special locations bit about pools.
ive also seen plenty without rods though.
That's going some with rods to get it down that low, I know it is possible but come on, 20 ohms, would end up spending more on rods than anything else.
Just found that reg, it says when pme is used to supply the pool or basin it is recommended to use a rod for equipotential bonding, that would mean the frame etc would be on a rod and pme? Surely it's one or the other?
That was my thoughts exactly.
i ran a 10 mm earth wire from the db to the pump unit and another 10mm from the unit to the rod.i got it down to 23ohm at the rod end.its in the regs for a reason I suppose but it's not that clear what that reason is.good old wiring regs you would think that after 17 editions it would be black and white though instead of a murky shade of grey
While looking through GN7 (for something else) hot tubs are mentioned in chapter 13 of GN7 amd1,
it says basically where a hot tub is in a room other than a bathroom then section 701 (location containing a bathroom or shower) is to be applied in full.
Where the hot tub is located outdoors then section 702 (swimming pools etc.) applies in full.
Wrt 702, supplementary bonding is required for all extraneous conductive parts in zones 0,1 and 2 irrespective of whether they are simultaneously accessible or not.
Very much depends on the location and what the tub is mounted on. If you have positioned the tub on bare ground/grass, then your asking for trouble!! The best mounting/positioning is on a hard wood decking base, with a decent distance of surrounding decking. Concrete or concrete and slabs is only a little better than bare ground, especially if there is reinforcement in the concrete.
Nothing wrong at all with combining a rod to a PME supply. What i have to laugh at though, is that your BS7671 calls for a 20 ohm Ra on a hot-tub with a PME connection, but 200 ohms on a TT system covering the whole installation!!! It's not as if 20 ohms is going equal out, say a 0.35 ohm PME earthing. I know what they are trying to do, but you'ld be Better of making the hot-tub a TT and be done with it, but not a 200 ohm TT...lol!!!
Hi E54,
As far as PME goes, I think this probably the time to consider TTing it, as you would for caravan pitches etc.
Edit: just read your post saying basically the same thing, lol
Reply to Hot tubs.... in the UK Electrical Forum area at ElectriciansForums.net
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
Anyone plumb a DIY hot tub? I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with...
siricosm
