Housebashing tools needed | on ElectriciansForums
Discuss Housebashing tools needed in the UK Electrical Forum area at ElectriciansForums.net
E
ed-ectrician
Starting housebashing and got a few tools but wondered what i was missing?
Got hand tools - screwdrivers, cutters, pliers, bolset chisel, saws, etc
test gear and volt meter
mains sds plus
18v sds plus
17v combi
12v impact driver
mains circular saw
bits
fixings
extension lead
temporary board!
any other stuff i have glaringly obviously missed that is really useful for you housebashers!?
PS getting a bosch multicutter (poor man's fein cutter!!) soonish.
Wood chisel, auger bits for the drill, small trowel, wet and dry Hoover, dustpan &brush. Plasterers paddle for the drill (mixing small amounts of bonding coat ect).
mastic gun.
club hammer, jimmy bar for floorboards. Cable rods. Laser level. Chaser.
I/PU: don't use tape for marking cables unless you have nothing else. Over time, the tape has a tendency to unwrap itself and you end up with sticky cables. It's better to buy sleeving (get stuff to fit 2.5 then you can use it on both sizes if needed).
And to add to the list: a wooden board with a small CU, sockets ect on for Temps
Cheers all! Got most of the things you all suggested too actually, my list was a bit crap! - had a few jars it's sat night and spurs won today for once!
My mains SDS and (for lighter stuff) 18v SDS with chisel bits are ok for chasing surely? What do you all mean by chaser? I always used sds with chisel for chasing. Some use angle grinder and bolster chisel. Bash it up with a sds chisel bit surely?!
Do i need a separate core cutter by the way? Can I use a 800w £100 hitachi 230v jobby with diamond core bit for extractor fans etc?!
Ed
i use my hitachi 100 quid drill to core a hole for a fan, and i think has damaged it.
when you pull the trigger it's like it slips till you pull the trigger fully... contacted guy of ebay and he said dont know conact hitachi.lol not a year old
a chaser is a tool that has 2 4" cutting discs. It cuts 2 lines, and you chisel the middle out.
Any drill can be used for core drilling, but at the risk of damaging it, or you if it hasn't got a safety clutch.
a proper core drill is designed especially for the high torque required.
Reply to Housebashing tools needed in the UK Electrical Forum area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
