How can I speed up? | Page 2 | on ElectriciansForums
Discuss How can I speed up? in the UK Electrical Forum area at ElectriciansForums.net
Oldbury
Hello,
I am an apprentice electrician doing work mostly on domestic 3 bed house rewires (do flats and other houses as well but most are 3 bed houses) we normally do the rewires in 1 day (start about 8 and finish time varies between 2-3 (if lucky) and 4-6 most of the time)
The issue is that it the it takes me too long to do the upstairs (loft, fit lights and switches and chop, Capp and fit sockets then clean up) and it can take me all day to do this and some times the people I work with have to come up and fits some of the sockets as they have finished the downstairs.
How can I speed up?
Thanks.
upstairs of 3 bed house, so guess at 5 lights and 6 switches (inc 2 way) 10 sockets and smoke det, 1st and 2nd fix in 6 hours (inc testing) thats 8 minutes an item inc stripping out old, chasing, fixing boxes and capping. Someone has had to much redbull and how fast is your mate, he must be breaking sound barrier. This is of course no lunch, speaking or breaks
my thinking exacly.
sounds like - old cables are reused lol
One of my sparky mates reckons he know a team of sparks that rewire houses in a day- 1st and 2nd fix. Every time he tells me about them he says "I know you won't believe me, I can't believe it my self but I swear they do it all in a day" he also says that they often leave a mess, huge holes left in the ceiling around pendents, often leaking pipes after where they have disturbed fittings or screwed through pipes but its still a rewire in a day.
Hello,
How can I speed up?
Thanks.
Experience and practise, after a few years you will want to slow down lol
I used to follow a 5 gang team that would 1st & 2nd fix a 3 bed house in a day....not including the plastering....that was done buy someone else!! They used "safety box's", these were in place between the back box and socket/switch front, so the plasterer could do his stuff and not have to disturb the wiring!! All RCBO aswell!!
Ah well so we're back to the "One day rewires- is it possible" thread. I thought we hadn't had one for a while.
Anyway, here's my experience of them.
A few years ago when out of work I got a call from an agency regarding domestic rewires for Mears, the rate was ok so I said I'd go. When I got there I was told it was what used to be known as a Sanatogen job - one a day, every day. The squad consisted of 4 sparks and about a thousand labourers, sparks were to pull cables and the labourers were to do all the donkey work of chasing, lifting boards etc.
One pair of sparks were given the RFCs to pull in, once that was done they went on to the single point stuff, cooker, smokes, shower etc, while the other pair pulled in the lights. Now with the job flooded with people it's really easy to get someone to stick a fishing rod up a hole then shout for them to pull it. I can assure you, dear reader, that a rewire in a day is easily achievable.
Where it falls down is quality. Chases are put in seemingly at random because not all of them were used all of the time, boxes not properly sunk or squared, holes in ceilings made with a hammer not a pad saw and (most damningly of all) short cuts taken on testing.
Trev, I know where your coming from.....as far as I know, the only tests the guys did was a Zs, Ze, Pfc!!!! That was just to make sure it was safe!!lol I would go in, about two weeks later, after the plasterer, kitchen fitter and decorator and do the full set of tests!!!! I was told, they didnt do the IR test because all circuits were on RCBO's and if there was a fault, the rcbo would trip straight away!!!!!
Makes you think!!!!lol
Jay, these monkeys would do a Ze and a global IR, if there was enough time(Lol) they'd test the RCD and that was it. The rest, they'd just make up, when I called them out over it they'd say "Well it's a rewire, you know it's all ok" I was bloody glad it wasn't my name going on the EICs
Exactly what they said to me!!lol "Its a rewire, if owt was wrong, the rcbo would trip within seconds"!! If I found owt wrong when I did the full tests, the company would send them back to sort it out.
All I can say, is that at the time I was still wet behind the ears and I did what they said!!! It was only after a few months, I reallised what I was actually doing!!lol
Reply to How can I speed up? in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
