how do you wire in a spotlight? | Page 2 | on ElectriciansForums
Discuss how do you wire in a spotlight? in the UK Electrical Forum area at ElectriciansForums.net
I want to start installing spotlights but I find the connectivity difficult as they don't come with ceiling roses. The only way I could think of is taking the switch wire to a junction box and then wiring the corresponding spotlights off it, can it be done this way? or what is the correct procedure?
OP:
where do you intend installing these spot lights?...(i take it you mean downlights)
have you checked to see if they need to be fire rated?
are they fire rated?
well they have to be fire rated, otherwise they would not be supplied?!
I want an understanding to install them in bathrooms, kitchens, bedrooms, livingrooms
Reply to how do you wire in a spotlight? in the UK Electrical Forum area at ElectriciansForums.net
I did take this picture before of the wiring in the spotlight if that helps. The earth is bottom right I cut this to get the sleeve off to put...
