How is a generator earthed and given neutral? | Page 4 | on ElectriciansForums
Discuss How is a generator earthed and given neutral? in the UK Electrical Forum area at ElectriciansForums.net
London
Hi
I have a question i cant seem to get an answer too.
If you have a portable generator and you plug for instance a fridge or any appliance directly into it, how is the neutral/earthing provided??
I know already that normally you can connect the neutral and earth from an existing installation
But what if you are for example somwhere random and i plug a fridge into a generator where is the neutral coming from? Surely it cannot be from the casing as if someone was to lift the generator up they would get a belt from the supposed to be neutral return path?
Thanks in advance
Ah! Straw man walking! Classic desperation!
No, actually, what it 'proves' is that I fully accept you're completely unqualified to comment on matters of electrical safety. And further consolidates my opinion (by dint of the dangerous suggestion you made earlier - that end-users might reasonably construct dangerous contraptions for themselves) that you're a danger to yourself and other people! - The sort of individual that gives Sparks a bad name in fact!
Unfollowing this conversation and the forum generally... Never argue with an idiot it's said; they'll drag you down to their level and beat you with experience! (of stupidity that is!)
Shame, I was looking forward to your explanation as to how 3 phase generation with star point Neutral relates to providing a Neutral in single phase generators.
...Were you? If you were a little brighter - possibly better educated - you'd have understood what I posted earlier. For completeness (and the sake of the hard of thinking) I'll clarify that they don't really 'relate' per se... And that the notion of 'neutral' in a supply derived from a single output coil (such as the secondary of an isolating transformer or the output of a simple generator) is nominal.
I was also quite clear (not that you'd admit it) that I wasn't going to get bogged down in the vagueries of the American split phase system - for the sake of clarity.
I'm sure you're an excellent swimmer and draw superb pictures of Faries when asked - possibly better if you stick to that. Now; do be a good chap and flock the flock off while I figure out how to unsubscribe from this forum!
Reply to How is a generator earthed and given neutral? in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
Thank you so much I have spent hours and hours looking for this answer, appreciate your time and comprehensive reply. I will look further into the...
