OP
rocker
day 1 temporary supply and taking out what electrics that were there. So 2 1/2 mans days each on chasing out and we've not even looked at the kitchen as yet.
I'd say to that if house is unnoccupied then temp supply should be a builder's board whacked into the tails featruring a 20A RCBO and just some extension leads, much quicker than messing around. Also, we know scrap is quite high right now but when you're up against it time - wise, just pull out what's easy and leave the rest plastered in the walls.
I agree with you chasing always takes longer than you'd think, but unless that's one crazy spec job 5 or 6 days chasing is a hell of a long time, even on a property that size. What tools are you using? You're not doing it all by hand, are you?
