OP
morph
10 way wylex fully loaded £65 + vat Electric Center. no quibble exchange. yes, you are being ripped at£85. do you buy from cef?
is that with your own choice of mcbs or a set selection ?
thnaks
Discuss How much for a consumer unit exchange? in the Talk Electrician area at ElectriciansForums.net
Well the board is 10 way with all the appropriate breakers needed to do a whole two story house. And they do go wrong, but my local wholesalers are good as gold for replacing faulty mcbs, rcds, rcbos.
I was thinking around about the £400 mark, with mains water and gas bonding all extra considering route, length, awkwardness running etc etc.
Although to be honest if I'm doing a job for someone who doesn't want inconvenience, its RCBO'S all the way. And at £28 a pop, the £400 price certainly goes up a quid or two ;-))
One question though. When you say £400, is that including a NICEIC Cert, or is that extra too???
mine the posh one with the touch buttons. >50v , and rcd test. ok it's about as accurate as CEF invoices, but as a quick test prior to CU change, saves some time.I go around with my plug in socket tester, honest
Reply to How much for a consumer unit exchange? in the Talk Electrician area at ElectriciansForums.net
