How much insulation is needed leaving back box? | on ElectriciansForums
Discuss How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
T
twist
Hi, I'm replacing a damaged cable to my shower and can't make a good job of getting both 10mm^2 cables in the old DP switch box without stripping the external PVC way back to promote flexibility.
The thing is these are massive cables and the one at the bottom comes from the top and vice versa, the opening at the back barely permits the two entry without needing to cross over.
Should I replace the switch or let cable leave without full outer insulation?
Is this a trick question? It sounds like your a victim of bad planning if the cables cross, can't you rearrange them so they can enter the box in an orderly fashion? Stripping the insulation way back to make them more flexible would not be a good idea. Maybe a photo would give us a better idea of the problem.
No trick, it's a wall switch, and now the cable is cut, it will forever be a wall switch and not a ceiling switch. I like it high, outside the shower room, and the shower higher still, safe from the torrents.
Ok, was going to do that.
I DIY I die, so no, but I repair and replace.
Seems most wall mounted DP switches are for cookers, anyone know if they will give the requisite 3mm contact separation and which standard I need to look for to ensure this? Or just buy Crabtree and trust in quality?
Reply to How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
