How much insulation is needed leaving back box? | Page 2 | on ElectriciansForums
Discuss How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
T
twist
Hi, I'm replacing a damaged cable to my shower and can't make a good job of getting both 10mm^2 cables in the old DP switch box without stripping the external PVC way back to promote flexibility.
The thing is these are massive cables and the one at the bottom comes from the top and vice versa, the opening at the back barely permits the two entry without needing to cross over.
Should I replace the switch or let cable leave without full outer insulation?
Ok, was going to do that.
I DIY I die, so no, but I repair and replace.
Seems most wall mounted DP switches are for cookers, anyone know if they will give the requisite 3mm contact separation and which standard I need to look for to ensure this? Or just buy Crabtree and trust in quality?
Hmmmm, ....so what sort of contact gap would you expect from a DP 45A cooker switch then??
you've had your answer. use a double 47mm back box and an appropriate switch.
[ElectriciansForums.net] How much insulation is needed leaving back box?
Originally Posted by twist [ElectriciansForums.net] How much insulation is needed leaving back box?
Originally Posted by Engineer54 [ElectriciansForums.net] How much insulation is needed leaving back box?
I don't know, I'm replacing my shower.
Yep, that looks decidedly like a cooker/heater switch, without the engraving of ''COOKER'' or HEATER'' on the faceplate!! Jesus, some mothers do ave em alright!!
Reply to How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
