How much insulation is needed leaving back box? | Page 4 | on ElectriciansForums
Discuss How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
T
twist
Hi, I'm replacing a damaged cable to my shower and can't make a good job of getting both 10mm^2 cables in the old DP switch box without stripping the external PVC way back to promote flexibility.
The thing is these are massive cables and the one at the bottom comes from the top and vice versa, the opening at the back barely permits the two entry without needing to cross over.
Should I replace the switch or let cable leave without full outer insulation?
Come on peeps. Everyone knows the outer sheath is only there to keep the cores together whilst wiring.
Reply to How much insulation is needed leaving back box? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
