How to add a bigger Back Box | Page 2 | on ElectriciansForums
Discuss How to add a bigger Back Box in the UK Electrical Forum area at ElectriciansForums.net
L
Lordy9099
Hello All,
Happy New Year! Anyway I have just bought a 2 way LightwaveRF dimmer switch, it is suppost to be used with a 35mm back box but the one installed is currently only 16mm and no way can I get it to fit, so my main question is how can I make the current 16mm hole into a 35mm hole without making a big mess. Also how do you make a cable bigger if it is getting a little too short, Choc block?
You can get collars from B&Q and the like, that go between the back box and the accessory.
These allow the extra space required when the back box is too shallow.
If your cables are too short, yes use a terminal block to extend them.
Get a ELECTRICIAN to do it instead of somebody f&ckin competant. I HATE that word competant and all its b&ll&cks definitions.
competent [ˈkɒmpɪtənt]adj
1.
having sufficient skill, knowledge, etc.; capable
2. suitable or sufficient for the purpose a competent answer
3. (Law) Law (of a witness) having legal capacity; qualified to testify, etc.
4. (postpositive; foll by to) belonging as a right; appropriate[from Latin competēns, from competere to be competent; see compete]
:laugh:
Reply to How to add a bigger Back Box in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
