How to flag / protect on a moled cable ? | on ElectriciansForums
Discuss How to flag / protect on a moled cable ? in the Australia area at ElectriciansForums.net
JD6400
Mentor
I have been told in the past ( All be a builder that wanted the job instead ! ) that it is illegal to mole cables underground as you can not install a marker tape with it !
What thoughts do others have on this one ?
Thanks in advance if you reply .
Dave
Interesting question. How about a second hole above the cable to pull the marker tape through! :)
Can be done , but very time consuming and you will need to have gone the extra depth with the first mole to still be in a workable moiling zone on the second one !
edit ; Plus if there is not enough distance between the two moles the first one will suffer for it .
As long as you install marker tape above the cable you are covering regs, so a small trench a few inches deep would suffice. However, good working practice is to surround cable with sand to protect outer sheath unless placed in a conduit or duct.
Thanks Mogga , generally the deeper the better and it should really be around 10x the size of the mole ( smallest ones i have seen are 45mm in diameter so 450mm down ) but i have seen them go in literally just below a skim of concrete before !
They can not be in contravention of the regs or surly the utility company's would not use them ?
Hi Guitarist and thanks for your reply , the trouble with that is the reason for using the mole normally is not to or it is impossible to damage the ground surface , so this is not always possible ?
I would say that to mark a moled cable you would have to mole in a pipe or duct, and then run the cable through that, the duct should be orange in line with BS1710, that would be classed as adequatley marked IMO
pipe marker, pipe markers, pipe marking, british, standards, UK, united kingdom, pipe labels, pipeworks, pipe labeling, labeling, label printer, pipe works, pipe safety, safety labels, safety signs, sign, warning, hazardous, chemicals, direction, BS
Sounds like the best way to me jase.
Never used moles to pull cables in buried cable installations. Not the best idea in my mind as there will be zero protection for the cable from sharp stones and other objects. Unless they have a way of pulling cable and duct in at the same time??
Reply to How to flag / protect on a moled cable ? in the Australia area at ElectriciansForums.net
