How to safely disconnect a noisy fan? | on ElectriciansForums
Discuss How to safely disconnect a noisy fan? in the Australia area at ElectriciansForums.net
A
Adam Fan
Hi everyone,
I’m looking to disconnect a noisy ceiling exhaust fan but I want to be able to reconnect it easily should I ever sell. I’ve attached a picture of the wiring from the roof to the fan. Can I simply cut the brown and black wires that are soldered on?
[ElectriciansForums.net] How to safely disconnect a noisy fan?
Reply to How to safely disconnect a noisy fan? in the Australia area at ElectriciansForums.net
It would normally be the outer terminals where the flex of the pendant drop connect.
It's actually all a bit academic as the grey twin and earth cable shouldn't be being used outside (not UV rated) so really the whole lot needs...
