Discuss How to stop screw together earth stakes unscrewing as you hit them. in the UK Electrical Forum area at ElectriciansForums.net
Why you're not using an SDS to drive the rods in the ground is a little confusing though, haven't seen a club hammer and the like used for bloody years now!! lol!!
fit a check nut to each section of the rods, screw rods into coupler then tighten lock nuts onto coupler
OR drill cross hole through rod & coupler & drive a tapered pin through. (not very practical on "twigs though)
OR use Loctite?? (may affect RA)
i thought about thread lock but it takes hours to cure.......
Rarely use couplers as we tend to use 2.8m rods, and bored holes filled with Bentonite or Marconite.
On occasions we do use couplers on driven rods, we braze the couplers to the rods. I'm sure a couple of pairs of stiltons to tighten couplers to the rods should be enough for those 1.2m rods you use in the UK.... Why you're not using an SDS to drive the rods in the ground is a little confusing though, haven't seen a club hammer and the like used for bloody years now!! lol!!
You should have been in Stockton the other week then, the first rod was pushed most of the way in by hand then I stood on it. The second rod was tapped in, the third was when I got the mash hammer out
The thread is pretty course so I was thinking maybe a few drops of superglue. If it's done after it's been wrenched up tight it shouldn't affect the resistance of the joint.i thought about thread lock but it takes hours to cure.......
Morning sir...Loctite is not what i would have a preference for,in this instance,but the OP was asking for a way of ensuring tightness. There would be ample galling of thread contact surfaces,to ensure electrical contact,which would be reduced in due time on a loose joint,by corrosive action. The Loctite product in mind,is released using heat,not impact,as it is used in applications where vibration and impact forces,are the reasons for applying it. I am guessing the "engineer" you mention,was applying Loctite to a busbar connector,if this ended up as an insulator...he patently did not purchase the Loctite himself,as pound for pound,it is dearer than heroin! :icon12:Loctite?
What’s the easiest way of getting a bolt out that’s had loctite on it, simple answer, hit it.
Now how were you going to put these rods in?
Loctite is an insulator, we found that out when one of our highly skilled (idiot) electricians got it all over a busbar connection.
I heat it up with a torch and fill the gap with solder.
Reply to How to stop screw together earth stakes unscrewing as you hit them. in the UK Electrical Forum area at ElectriciansForums.net
