How would you change this. | Page 2 | on ElectriciansForums
Discuss How would you change this. in the UK Electrical Forum area at ElectriciansForums.net
Berkshire
How would you go about changing this unit over?
[ElectriciansForums.net] How would you change this.
Old wylex board with Pyro mains tails. Earthed via Pyro, and all circuits via conduit.
Protrudes out the wall so I was thinking 1 of options, as I can’t see any other way round it.
Option 1
Batten on each side of the DB to the same level of the current one, crimp all cables and mount new unit over the old one.
Take a 16mm cpc from old board to new board.
Option 2
Angle grind the DB so it’s level with the wall and do same as above.
Option 3
Remove current DB completely and try to get another one in the same space, attempt to alter conduits and pyro to fit.
Don’t fancy bending pyro!
  • [ElectriciansForums.net] How would you change this.
I think a Wylex skeleton CU would be an option to fit into the existing enclosure, if it would fit it would be the neatest outcome IMO
,& yes a rewire would be better,& a recommendation to the client.
Why would it be necessary to rewire? if the installation test out ok there is no point
Great idea if it fit. If it doesn’t what then?
Is it permissible to use different components from different manufacturers to build a board?
im surprised there isn’t something out there ready designed for this issue as it is not uncommon.
Don’t like doing Frankenstein jobs but in this instance I don’t see how it can be avoided, but in doing so are we breaking our regs.
Personally I would either do a full rewire or walk away. But I would let customer know there could be electricians out there who are willing to do a Frankenstein job.
im not criticising either option, just giving my take.
Doing a full rewire through all singles in existing conduit will make no difference to the situation, unless you ditch that and chase t&e in everywhere.
You cannot grind a CU down as you suggest. You are now the designer if anything should happen.
I don't think they are suggesting grinding down the replacement CU, I think it is to level the old metal to the wall and then mount a new external one over the top.
In that case the old CU is simple a large box and the only real issue would be safely and professionally extending the cables to reach in to the new CU. For most of the cables probably MF boxes would do if the fit in the remains of that old CU behind.
Not so sure about the pyro, but I would be inclined to use bare crimps and glue lines heat-shrink to extend the pyro's tails. At 60A and enclosed as it is you could use 16mm tri-rated for that, assuming proper crimps and ferrules to match.
But I might have missed something blindingly obvious here.
Actually one blindingly obvious thing just after posting is the pryo cables might be a lot less than 16mm so common crimps won't be OK as they are not size-converting.
Might be a job for a couple of big DIN terminals?
The best option would be, giving that the client would have to forebear decor etc, carefully dig out the CU, keep all existing lock rings/lock nuts in case imperial sizing, obtain a cu with no knockout's, make up template and pre drill for conduit entries, refit existing lock rings/lock nuts hence no need for joints etc, like for like retermination.
That would be ideal, but given there is conduit entering both top & bottom it might be difficult/impossible to remove the old CU, or indeed find one to fit the same conduit-conduit spacing that can be inserted again and conduit attached.
I see a whole lot of re-threading pain going down that route...
Yes difficult, without seeing the job it's hard to see a good solution.
It's a Wylex 3036 board if a Wylex skeleton board fits in the enclosure your not mixing different manufacturers components
The problem is some of these sites were originally a bespoke solution for each developer, 60 years on and an adapted solution is the only way to replace them
Not sure why you term this type of job a Frankenstein job is it because there is no out of box solution
Whats made it a ball ache, using threaded conduit entry with lock ring and a female bush, that is rubbish I always use socket and male bush for this type of install.
Done 50-60 years back........maybe they ran out of mb bushes or couplings. Just a couple of lads dropped off on the job, stuck in the middle of nowhere, no van, no phone..........and they don't know the code for smoke signals....give 'em a break for using their initiative. ?
Sorry. I read it as cutting the back out of the new Cu to fit over the old one. My bad - as the youngsters say ???
Frankenstein job is basically taking components from different sources that where not designed to go together and adding them together to or incorporating into an older product.
So yes, “no out of box solution” that’s about the reasoning behind it.
rip out the innards. fit din rail, main switch and RCBOs . get a lid fabricated, (needn't be too fancy, any F**k ups will be covered in stickers anyway),
Reply to How would you change this. in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
