HV Earth System & LV earth system | on ElectriciansForums
Discuss HV Earth System & LV earth system in the Talk Electrician area at ElectriciansForums.net
marc8
Essex
Hi All
late last year & early part of this year we had been asked to install customer HV earth system & LV earth system to a drawing supplied.
all went well after some messing around trying to get Rods installed in frozen & water logged trench.
all readings fine & the cad weld system all went well. I sent the readings to the engineer for each rod & cable install he was happy. been asked to supply a certificate for this side of the works HV & LV earth system.
has anyone got a template or should I just use an electrical certificate for the works ?
any help would be appreciated.
If there was an engineer supervising the job and you were working to his specifications then he would usually be responsible for certification.
Hi Marvo
just had to report my findings to the engineer to determine if he wanted to visit site or not to have a look at works, all done by photos & readings he was happy with readings & photos of works.
I was contacted yesterday to ask to supply certificate for the works & requested to be at site later in the month for verification of the earth system when sub station is installed.
Reply to HV Earth System & LV earth system in the Talk Electrician area at ElectriciansForums.net
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
You would treat it as a TT installation.
