Hi all
Looking for some wisdom
I installed a Hypervolt charger (the most recent model which is no longer available for direct purchase fr Hypervolt)
It’s on a smart octopus setup
Works perfectly fine on scheduled charge
But when doing an Octopus ‘bump charge’ , Hypervolt says voltage falls to 207v and shuts off.
It tests fine, distance is 3m from main board. Using 6mm EV ultra cable for connection.
Connected to a spare way using a 40A Type A breaker bidirectional ) on the main board
There is a ct clamp for fuse saving
Have I done something wrong ?
Or is this a unit or software issue?
