Hypothetical question | Page 2 | on ElectriciansForums
Discuss Hypothetical question in the UK Electrical Forum area at ElectriciansForums.net
J
jdd
If you had a steel framed building with the electrical service at one end and the gas/water service at the other end. Would it be possible to bond the steel as normal, but then just bond the gas/water service straight to the steel work, instead of taking back to the MET.
It's one of my favourite pinball back glasses from the golden era of 70s pinball artwork.
I'll reinstate the old mush if you really want, too wrecked at the moment.
[ElectriciansForums.net] Hypothetical question
Full avatar, a Schrage motor.
To this day I’m still not sure how they work. Only ever seen them on German printing presses. The speed is varied by the brushes being moved further apart. So you would have a motor controlling the speed of a motor.
Weird things! Like me before you get your oar in!
Interesting object!?!
You really should try 3d AutoCad, you've got the basics.
As an engineer of your years I should imagine you've got the spacial awareness to stroll this.
Just tried putting up some 3D images but failed.
Getting back to the original question, No idea why there are some here, that think a steel framed building that's been bonded and probably providing a pretty decent earth in it's own right, can't act as a bonding conductor. Whole factories use the steel framing of steel framed structures as it's bonding medium, for all of the factory plant and it's fixed equipment... You would need to install a huge copper conductor to match the volume and paths of conductivity that the steelwork will provide!! lol!!
No I wouldn't. I would price accordingly to run the bond to the gas and water.
You must be very naive if you are thinking that the mass of steel in a steel framed building isn't going to be superior, than your 10mm or whatever bonding conductor!! ...God knows what sort of money you'll be asking for all that cable, cable fixing and/or containment!! lol!!
Reply to Hypothetical question in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
