Hypothetical question | Page 3 | on ElectriciansForums
Discuss Hypothetical question in the UK Electrical Forum area at ElectriciansForums.net
J
jdd
If you had a steel framed building with the electrical service at one end and the gas/water service at the other end. Would it be possible to bond the steel as normal, but then just bond the gas/water service straight to the steel work, instead of taking back to the MET.
Been doing this for 28 years on large construction sites gas and water still bonded so i am not naive but you obviously think you know it all lol
Well i obviously know a bit more than you after your 28 years!!
Perhaps you can explain why you would pull a separate bonding conductor over several tens of metres of a steel framed building, rather than using the mass of steelwork that's already bonded to the MET??
Reply to Hypothetical question in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
