I need help with an electric shower wire which is too short | Page 2 | on ElectriciansForums
Discuss I need help with an electric shower wire which is too short in the UK Electrical Forum area at ElectriciansForums.net
Umarhafiz
M192lx
We had our bathroom renovated about 10 years ago and the original builder had left the shower wire too short and i didnt bother to get it fixed right away as we had another shower in the new loft extension done by the same builder around the same time. A few years go by and i then decided to ask someone to have a look and suprisingly no one had a simple answer i dont know if the electricians in my area are no good or it genuinely is a difficult or risky thing to do. to this day i have not found anyone who wants to do it so i have come here to get a better idea of what i could do or what is the best option. The bathroom has been tiled and there is a bath tub under where the shower is meant to be. Sorry if ive not given enough information im not very clued up when it comes to bathroom wiring or any wiring really.
The “shrink” part of crimp n shrink is heat shrink sleeving.
it goes around the crimped cables, and when heated will shrink and pull tight against cable and crimps, just for added safety. Much more robust than insulating tape.
it is a simple job for someone with the right tools. As mentioned, you could have 40A running through it, and you don’t want to be in the shower when that joint suddenly fails.
Ok that makes sense thank you
You would also need to put some decent heatshrink around all the joints and both cables.
You also need to consider if It might actually be cheaper to get someone in to do it as you'd need:
-a short section of 10mm T+E (and probably have to buy more than you want)
-2 x 10mm crimps
-1 x insulated 4mm crimp
Heat shrinking in various sizes
6mm earth sleeving
+ Crimping tool if you don't have one
It all adds up!
-2 x 10mm crimps
6mm earth sleeving
It all adds up!
Yh i was thinking that as i also wouldnt know if ive crimped it properly and stuff like that anyone know how much i should be paying for a job like this?
If you have space to put it in, and it is definitely away from any water, but you have some means of accessing it for any maintenance, then something like this junction box is a better bet:
If it were me and I could somehow get the cable in the roof space above it, then using something like that and a longer run of new wire down to the shower would be easier.
Reply to I need help with an electric shower wire which is too short in the UK Electrical Forum area at ElectriciansForums.net
"Value engineering."
2 3
5K
M
Tiling on Universal Shower Bases Hi there - I’m hoping to get some advice. I’m a builder, based in Melbourne, Australia. I’ve recently done a...
Melbourne Builder
M
