I never install ring circuits, the potential for danger is unacceptable | Page 5 | on ElectriciansForums
Discuss I never install ring circuits, the potential for danger is unacceptable in the UK Electrical Forum area at ElectriciansForums.net
ZEDEZ
London
I’d like to know if anyone else here refuses to install ring circuits in domestic premises.
For me it’s either a 20a radial / tree circuit with 2.5mm, or a 32 radial / tree circuit with 4.0mm.
Frankly I’m tired of finding broken ring circuits on 32a CB’s, as well as mismatches on end to end tests. It drives me nuts on jobs that should be simple.
I wish we would get rid of this ridiculous practice here in the UK.
I know some of you will say there’s nothing wrong with it when it’s properly installed and tested, but inevitably at some point in the future someone will come along and disconnect a conductor unknowingly while changing outlets on the circuit.
Testing is more complicated, and diagnosing faults on a ring also.
Same old argument. "Ring circuits are dangerous if someone who has no clue messes with them." Same goes for any circuit.
I find precious few ring final faults and have never seen any substantial evidence that significant danger is posed even when rings have been made discontinuous. Only in theory.
Anything installed properly is safe. Anything installed then messed with has the potential for danger. The argument has no point.
I think the OP uses 'tree' to describe an ad-hoc radial with branches but it has a much older, more established meaning. The tree system of wiring was used in the late 1800s and early 1900s as an alternative to the distribution system that we use now (i.e. terminating a main or submain in a DB and distributing circuits from there).
In the tree system, the main would take a shortish, straightish route through the building and wherever a circuit was needed, a local fuse would branch off. Like taps in a riser busbar, but not necessarily in a riser. The main could also taper like the trunk of a tree, as it could be fused down stepwise as branches relieved it of some of the load. Pattresses with one or two pairs of ceramic pepperpot fuses would be dotted around here there and everywhere, resulting in difficulty of isolation and localisation and inflexibility once installed.
The advantage of a tree, in some layouts, was that less wiring and shorter runs were often possible, giving lower drop for the same amount of copper. But the flexibility of the DB method had won out by the 1920s and tree wiring was soon abandoned.
When the topic was last aired, I said I would like to see examples of thermal damage to RFC cables caused specifically by overload of one leg, due to the other going O/C. None have been offered so far...
Personally I've never come across a RFC that was broken and then overloaded. My opinion is that its not likely to happen in most homes, possibly the kitchen where there is a potential of higher wattage equipment being simultaneously used (which is one good reason to wire a kitchen on its own RFC). Again my personal opinion is that RFC's are less likely to be dangerous should a fault occur, an example, as a few have already mentioned - the continuity of the cpc is more likely to remain intact or at least partially intact for the majority of the circuit.
The only one problem I see with RFC's - The ignorant people who don't understand them.
Sorry O.P but you don't have my vote.
Reply to I never install ring circuits, the potential for danger is unacceptable in the UK Electrical Forum area at ElectriciansForums.net
