I would post this in the trainee forum but I havent been accepted yet | on ElectriciansForums
Discuss I would post this in the trainee forum but I havent been accepted yet in the UK Electrical Forum area at ElectriciansForums.net
L
lofts
so I will fire away.
Im working on a house at the moment that has 2 rings. one up and one down. the one downstairs has the kitchen on it so I am going to put a new kitchen ring in which will leave three rings in total. upstairs ring,downstairs ring and kitchen ring. as the kitchen ring is one the downstairs ring currently I obviously need to joing the cables that were done so via the sockets previously so it remains a ring as such. I was going to use Junction boxes but I was wondering if I could use these instead
LINE 32A 3 Port Push In Connector [L3P32] - ÂŁ0.14 : for electricians by electricians
Live ------------ -------------- Live
Earth ----------- -------------- Earth
Neutral --------- -------------- Neutral
would I just connect one to each end of the cable making sure each one is put in the same or .......
thanks for any help
Im working alone mate, I sound worse then what I am I think. Its just if your unsure its best to ask I find. I know I could pop that lot into a JB but id sooner use these as theres less chance of a scress coming loose and causeing a fire, especially as there going to be under the floor boards so fairly unacesable plus its faster as less labour intense.
So one on each end ont he cable and then into a chock box.
any chance you can let me no if I can get on the training forums so I can ask question after question
If the connections are going to be under the floorboards and inaccessible then they should be maintenance free and Line connectors are only maintenance free when derated to 20A (and in a line enclosure) which is pushing it on the CCC for a ring leg. A chock box is not classed a part of an MF assembly.
Possibly try Ashley 32A MF junction boxes.
Not at all your just winding me up all the time. I do t know why u bother posting in my threads u clearly think u a cut above the test.
Is there not a option so I can opt out of seeing what you post
The connectors will be fine provided they are installed correctly Lofts.
Fence sitting at its highest here, not even going to say anything, but if I was banned with a previous user name and a forum was of 'much value' to me, I wouldn't reinvent myself by dropping an 'S' for a 'Y' on said forum.
Reply to I would post this in the trainee forum but I havent been accepted yet in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Why aren't you asking them?
