Ideal twist connectors
S
stan794
Any of you guys using the Twist connectors from Ideal?
On a recent Kitchen refurb/extension my spark used them on the lighting circuit and LABC are moaning saying they are prone to causing electrical fires. I must admit I prefer wagos myself but these twisters are to BS7671 so why are they moaning... ****ers :(
line for me. yesterday got 6 1.5mm into a line enclosure with connectors. try doing that in a 2" round screw JB.
Wouldn't use those twisters in a million years. Are you sure they have a bs / en number?
Keep an eye on this thread Stan, Eng54's imminent response might amuse you
Haha....​
At least your LABC have some sense it seems!!
Don't touch those fire nuts, the only place those things are commonly used are in the States and countries where they follow NFPA 70 (NEC). They are known to be the major cause of electrical fires in their domestic installations, but the numb nuts still insist on using them. Literary any other form of connector is going to be better than those bloody things!!
I'd be quite shocked to learn they conform to BS 7671, They would need their own BS/EN number to even come close, ....and if they did it would be another area of BS7671 that i would be ignoring!! I think it was in one of the 14th editions of the reg's where it actually stated that twister connectors are NO longer recommended as means of connecting two or more conductors....
Not that I have ever used them and likely never will
They are surely not designed for solid core conductors ?
I am presuming that solid core was the case
I wouldn't of thought so myself, but many of the Yanks wire and cables are indeed solid core. They need to be, as the standard terminal connection on their over sized light switches and dual socket outlets are by means of wrapping round a captive screw!! That's Yanks for you... lol!!
Thank you matt for that link
It seems my thoughts were wrong and they are for solid core as explained by eng 54
The guy did a good demonstration.but twisting a solid core in that way would make me feel very uneasy and I can well understand the building inspector saying "not on my patch"
if I were him,it would be the same action
stan794,
old_sparky_RE,
