I'll say no more.... | Page 3 | on ElectriciansForums
Discuss I'll say no more.... in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Check this put, this wasn't the problem. But found it whilst looking and felt I had to take a photo!
100+ year old house, lady says there is a banging coming from the electrics, I said ok I'll take a look, she said it's above the bathroom ceiling, like a firework going off, a large cracking noise and a flash that you see from the loft hatch.
The house looked over 100 years old inside, looked like the original decor etc, I didn't go up to look at what it was I. The loft as the entry to the loft was via the hatch above the stairs and it would have been sodding dangerous getting I to it, I said it's too risky.
anyway, here's a pic
  • [ElectriciansForums.net] I'll say no more....
So what was the point of posting a picture of a circuit that wasn't at fault to try to justify you were too incompetent to get into a domestic loft to sort out a potentially dangerous fault for an OAP?
Shame.
If I had seen the loft I would have found a way of getting up there.
Coming back in an hour or two with a mate and a longer ladder would probably have been my soloution.
Failing that, if the loft hatch is really that impossible to get in to then cut a hole in the ceiling as near to where the banging is coming from.
I never said she was old?? Did I? She was early 40s.
honestly if you had seen the loft you would have said the same.
i won't bother posting things up anymore.
uk, nobody here has seen the situation. i'd not make a negative comment without seeing it. take no notice of the negatives. i'd like to think that you'd be finding a way of gaining access. if it means hiring access equipment , you have to advise the client of the cost and then go from there.
Reply to I'll say no more.... in the UK Electrical Forum area at ElectriciansForums.net
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
