I'm going to get slated but.... | on ElectriciansForums
Discuss I'm going to get slated but.... in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
I've managed to get a 450mm SDS (10) masonry bit jammed solid, going up at an angle above a door frame. I think it has got stuck at some reinforcing in a lintel. I have about 50mm still showing, but can't get the bl**dy thing to move. It's in a domestic property and the lady of the house ain't best pleased.
Any suggestions as to how I might retrieve the offending item ( and yes, I feel like a right t*t!)??????
Hang on......a 100mm lintel, and you've lost 400mm of drill bit in it?
Cut it off flush with an angle grinder and start again?
Wouldn't have thought of that! I would have just panicked!
Of course he'd have to bond it :wink:
Thanks all (I think?). If I can't shift it I'm really boogered. Won't be able to get in close enough to cut/grind it off.
Simonslimline- can't quite get the "spanner" suggestion, can you explain?
Didn't resort to the lump hammer, yet!
It's an old property and I wasn't expecting a concrete lintel, but it's the only reason I can think its stuck fast.
Trev, I know, what can I say, I take things like this to heart.
I've tried reversing it out, but the clutch just breaks....I think I may have burnt out my SDS trying to dislodge the bloody thing.
It's an SDS bit so a spanner can grip the end enough to twist it a bit. It worked for me in the past. Good luck by the way.
Simons idea might work Polo.. worth a shot, although 400mm stuck is quite a bit! Are you sure there is no way you can get a small angle grinder to it? Perhaps an oscilating (multi purpose) saw with a decent metal cutting bit, this would take ages but it can get into smaller areas than an angle grinder?
But don't start whacking it until you've exhausted all other options
as you'll splay the shaft and never get it back into the chuck!
Reply to I'm going to get slated but.... in the UK Electrical Forum area at ElectriciansForums.net
