Immersion Heating PV Electricity Supply > ElectriciansForums.net
Discuss Immersion Heater - PV electricity in the Central Heating Systems area at ElectriciansForums.net
Hi all. These recircculating pumping systems seem all very neat but by the time you've bought a decent pump, two thermostats etc the overall cost sneaks up appreciably. Just wondering if anyone has had any experience retrofitting a second immersion heater at the bottom of the tank? On reflection, shame but at a glance the central heating coils of a standard tank seem to sit too close to the bottom to fit a standard immersion anyway.
That is the problem! Also I didn't fancy cutting the hole just in case I couldn't then get a proper seal. Remember that the Essex fittings for that size 2 1/4 inch also have a cost plus that of another heater and then you need to consider a contactor and thermostat to switch over between the two or you might just have a full tank of luke warm as opposed to a half tank of hot water which is useable.
The longest top fitting immersion that fits is not inexpensive. Or if you live in a hard water area bite the bullet and change your tank for a taller or dual element one. It’s going to fail someday anyway due to the hard water.
I changed mine from a 27 to a 36 which just clanged the coils while rotating during fitting but was clear when tightened up checked it with a fibre camera. however the temperature reached before cut out as measured by thermocouples every few inches up the tank hardly changed still at least I now had one of the newer ones with the extra safety stat.
I am also keen on this system and have been "lurking" on this thread for several months waiting for the progress that now seems very close.
echase - can you please send me details if this is available to buy.
I have also wondered about how to best use the hot water this generates, and was thinking about putting a thermostatic mixer valve in to the feed for the dishwasher and washing machine (both cold feed only), to give them warm water at about 30-40C. Thinking that this will reduce the amount of electricity they use in heating up water, which will mean they draw less from the grid, and leave more to heat up water...
This is exactly what I've done. The washing machine runs off a 30 degree feed off a short pipe run from the cylinder. Dogs have a nice warm outside tap for washes too!
I think they work best when they start with cold water, which washes certain foods off before they "bake" on.
@OldGrouser from what I recall (can't find it now on the Engensa site), their Solar 24 IS an ImmerSUN, - by the way an install shouldn't be 'from ÂŁ600 plus VAT' - that's a rip off.
Hi. I have been slowly pulling together the kit for the simple 12v circulating pump system described by Duplada, all at reasonable cost. Over some months I've drawn a blank on the 12v KSD9700 60 NO thermostat though - my only outstanding item. The NC variant seems readilly available from e.g. ebay. Anyone got ideas on sourcing KSD9700 60 NO (preferably with metal casing) or a alternative?
thanks
Mo
Hi Maurice,
When I purchased my KSD9700 NC/NO switches from eBay, I looked for a seller who listed a NC version and then asked them if they also had a NO version. I suggest you do the same. Search for a seller chinaeproducts (they don't have any listed at the moment) send them an email and tell them what you want, this is where I purchased mine.
Alternatively you could use these, search on ebay for KSD301 60 these switches have better hysteresis than the KDS9700. The KDS9700 switch at 60 +/- 5 degrees and reset at 40 +/- 10 Degrees. The KSD301 switch at 60 +/- 3 Degrees and reset at 45 +/- 5 Degrees. The KSD301 also have two lugs which you can use to secure to the tank with elastic.
Hope this helps.
regards Duplada
Reply to Immersion Heater - PV electricity in the Central Heating Systems area at ElectriciansForums.net
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
