Immersion heater wiring | on ElectriciansForums
Discuss Immersion heater wiring in the UK Electrical Forum area at ElectriciansForums.net
cambridge
I've recently moved into a house and would like to check please whether an immersion heater that looks recently fitted has been correctly wired.
It's rated at 3Kw and is wired with 2.5mm2 cable from a 16a MCB. The isolator switch is embossed 'immersion heater' and matches the images of 20a double-pole immersion heater isolation switches I've seen online.
Does that look ok?
Many thanks.
Reply to Immersion heater wiring in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
Thread closed.
2 3 4 5 6 7 8
4K
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
