T
the chippie
can sombody tell me why the blue wire on the immersion heater keeps getting hot and melting its casing
Discuss immersion heater in the Talk Electrician area at ElectriciansForums.net
is 'buytle' a thing of the past?
can't spell it, but some of you might get my drift I reckon.
Ask for 2.5mm 3183 TQ
Is the bottom heater on an 'off peak' supply?
If so then it will probably be 'on' far more than the top element which only heats a much smaller portion of the tank.
feeling hot hot hot....
use 2.5 butyl flex, is intended for emersion heater wiring
Reply to immersion heater in the Talk Electrician area at ElectriciansForums.net
