Imperial Conduit Problem? Imperial Dies? | Page 2 | on ElectriciansForums
Discuss Imperial Conduit Problem? Imperial Dies? in the UK Electrical Forum area at ElectriciansForums.net
GarryJ
Ayrshire, Scotland
Evening.
I was wondering if anyone knew or has sourced Imperial metal conduit Dies?
I have a job coming up in an old mansion house where there is existing imperial conduit drops down to a consumer unit location above a ceiling which is accessible through a large hatch right at the DB. The customer however wants to raise the ceiling and I am going to need to fit new board etc which is not a problem. However there are 5 existing imperial conduits come down through the ceiling above which I am going to need to very carefully cut them at a higher location and try to run a new thread on them further up where I can bring them into a large galv joint box and get appropriate lockrings etc etc for them to remain a good earthing system with the single core pvc cables within them.
Unfortunately I would have liked to lift the floor above and take the pipes back to the next box and re jig and rewire it all from there but this is not possible due to massive newly tiled floor bathroom above.
I am aware of the imperial to metric adaptors however I need to cut the pipes further up and then re thread. Anyone any other ideas? I could obviously put earth clamps round each of the 5 pipes at a nice clean location but this would look a bit scabby I think
Cheers in advance for any thoughts
That's odd Dave as that's what pipe clamps may have to deal with in unfortunate circumstances ? Then again some nice thick copper strip bolted through between each conduit to create a sort of sandwich would do the trick.
Bizarrely I did have a copy of the actual spec for a bs951 clamp somewhere, I'll see if I can find it.
Just looking at them I wouldn't trust them as part of a cpc, but maybe that's just me.
Thanks for the replies guys. Its a difficult one. Will take a photo and upload it to show the problem better.
The bathroom above the location looks to be around ÂŁ400 per floor tile and about the size of my full house
You may have to forget your usual rates here and price to reflect the nature of the job, sounds like they can afford it. ;)
could you not cut the tube high up as you say, and then put on the imperial to metric adaptors(which hammer on if I remember correctly?) and then just bush into your board?
if it's high up next to the ceiling no-one should see it anyway?
but like has already been said it's going to be tricky cutting the tube, and not sure how you could thread it even if you do get imp dies
I have heard of this type of adaptor, but never seen one.
There is a manufacturer of conduit that I think does up by Alan key it apparently has full B.S approval just a thought
Electric Centre had this in their catalogue at one time but now it has disappeared maybe it didn't catch on.
Conlok conduit systems that's the name google it. Used them knock on conduit adaptors as posted above IMO I would not rely on it for earth continuity. Although conduit has to be electrically sound is it being used as the C.P.C.
They don't manufacture it in imperial sizes though. And it's utter rubbish, it was used locally in a new entertainment venue. We did the first show in the venue and those conlok fittings were already failing in places where they'd had a little tap.
You have 5 metal conduits coming through the ceiling and you want cut them and re thread then in situ, well I wish you all the luck in the world Garry, without a picture it's difficult to advise but personally I think your idea is a non starter. What circuits are in these conduits?
Also my thought, I'm imagining all kinds of collateral damage cutting, removing, threading and installing while working up a ladder 4m ... hopefully I just need my happy pills.
Maybe leave in situ and adapt at the CU? Then you can adapt/bond/clamp or whatever in the privacy of your own home.
Reply to Imperial Conduit Problem? Imperial Dies? in the UK Electrical Forum area at ElectriciansForums.net
