M
malcolmsanford
I don't think you have a fault or an overload issue, you say in the OP that you have thermal overload relay if it was an overload issue then that would pop.
Also if it was overload the 16amp would pop first. Unless as was suggested you have a myriad of other things coming off that 40amp MCB that when the router starts up takes it over the top......then you have some issue with the 40amp breaker
It may very well be a dodgy breaker, it as been known that new accesories fail.
Try fitting the fuse, honestly my post about it was a little tongue in cheek, but I stand by that unless there is a reason not to I would always design a distribution circuit with a fuse
