Hazard a guess between the break. Although it could just be a loose connection if he puts some time into testing
Thanks.
So if I reinstate the ring then I can upgrade the MCB to 32amp and just issue a MWS. If the circuit requires new wiring which can't fulfil all the conditions of 522.6.101 then Ill insist it requires some form of RCD protection.
Went to a house yesterday where the customer was complaining of a tripping fuse on the kitchen circuit.
Got there and found the kitchen wired to a 20amp plug in MCB. The kitchen was not on a ring despite 2 wires being present in the board.
I confirmed a break in the circuit but didn't resolve wether it was a disconnected wire or a break somewhere. I was in a hurry I have to admit and made the assumption that someone with some insight deliberately derated the circuit to account for there being an irreconcilable break so I ruled out a loose wire.
I advised that she would require a new fuse board if I was to make good the wiring in the kitchen. Afterwoods however I wondered if perhaps there was a loose connection.
If so and I repaired this could I upgrade the capacity of the MCB to 32amp under current regs?
cheers.
The thing is, the OP is more interested in fitting a new DB rather finding either the fault or clamping the circuit and seeing what it is actually pulling.
Were all r1, rn and r2 all broken? Maybe it would be suitable to separate into two 20A radials to increase capacity depending where loading is. It is always a good idea to add RCD protection to socket outlets when opportunity arises. I agree RCD add ons is untidy. Do it right with a new CU. I talk them round and upgrade 3036 / 1361 boards whenever I see them in houses.
