induction hob cable size | on ElectriciansForums
Discuss induction hob cable size in the UK Electrical Forum area at ElectriciansForums.net
leep82
Stoke on Trent
Ive been asked to install a new circuit for an induction hob. The customer doesnt have the appliance as of yet but after a little bit of searching i managed to find the technical info i was after. The total load is stated as 3.68kw, but it also states that there are 2 x burners rated at 1.4kw and 2 others rated at 1.8kw. Obviously adding the burners together gives me a rating much bigger than the 3.68kw stated. As the kitchen is due to be plastered this week i need to get my first fix done for this circuit and was just wondering whether to cover my arse with a cable big enough to take the load of the 4 x burners or whether a diversity factor has been applied and i should just work of the 3.68kw total load.
Although you havnt really helped have you, where do you get your 10kw from. Is this the 4 x burners added together with the 3.68kw total load? If so why isnt the total load stated as 10kw? All youve done is try to be cocky and completely missed my my point with your accusations, i can only assume you know everything with such an attitude.
By my calc assuming the full load is ~ 10kW @ 230V = 43A. With diversity = 10A + 30% (43 - 10) + 5A for a socket if fitted ~ 25A
I doubt whether 3.6Kw includes diversity as this equates to ~ 16A. The only thing I can think of is does the cooker allow you to run everything at once? Some limit the total load that can be applied at any one time so maybe thats what the 3.6kW refers to?
If in doubt give the manufacturer a tinkle ......
So what size cable are you going to put in then?
Given my uncertainty over the total load and the fact that i have a little bit of cable on my van going spare going for 6mm2, after all what will do a lot will do a little. Its just about covering my arse as i initially stated and was after people opinions on whether they would also err on the side of caution, given the time restraints on the job. What i got was sombody questioning my ability and trying to teach me how to suck eggs.
The thing is pepparz i only wanted help with what i have interpreted as the total load. I am quite capable to work out the correct size of cable once known. People are to quick to jump on you on here, take the moron who was first to reply for example.
Reply to induction hob cable size in the UK Electrical Forum area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
