induction hob cable size | Page 2 | on ElectriciansForums
Discuss induction hob cable size in the UK Electrical Forum area at ElectriciansForums.net
leep82
Stoke on Trent
Ive been asked to install a new circuit for an induction hob. The customer doesnt have the appliance as of yet but after a little bit of searching i managed to find the technical info i was after. The total load is stated as 3.68kw, but it also states that there are 2 x burners rated at 1.4kw and 2 others rated at 1.8kw. Obviously adding the burners together gives me a rating much bigger than the 3.68kw stated. As the kitchen is due to be plastered this week i need to get my first fix done for this circuit and was just wondering whether to cover my arse with a cable big enough to take the load of the 4 x burners or whether a diversity factor has been applied and i should just work of the 3.68kw total load.
Although you havnt really helped have you, where do you get your 10kw from. Is this the 4 x burners added together with the 3.68kw total load? If so why isnt the total load stated as 10kw? All youve done is try to be cocky and completely missed my my point with your accusations, i can only assume you know everything with such an attitude.
oh....
i can assure you he dont...lol..
Thanks iamelectric i did wonder if this is the case. So in this thread alone i have a few different answers, so not as obvious as some people suggest. Theres even another thread started and i can only assume they are reffering to this thread of mine when they complain about people not knowing how to apply diversity! Now where do i say i dont know how to apply diversity?
the manufacturer has done the diversity calculation for tou and 3.68kw is about right
If they have done this calculation for you they would need to stipulate that it is for 'normal' domestic use and presumably assume you have a socket outlet on your cooker switch?
Bear in mind the calculation of diversity allowance is the responsibility of the installer - not the manufacturer.
You could be installing this hob in a commercial kitchen.
lol just take it on the chin mate its just part of this forum , doesnt matter what you ask you will get all sorts of ---- off people , just go with it
Sorry matey, can't agree with that. Just need to think about what you post, the more constructive the OP, then the more constructive the replies will be.
and the problem with my OP is what exactly?
Reply to induction hob cable size in the UK Electrical Forum area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
