Induction hob correct install | on ElectriciansForums
Discuss Induction hob correct install in the UK Electrical Forum area at ElectriciansForums.net
Dublin
I’ve been looking for the right answer and just can’t seem to find it.
I had an induction hob installed by a certified electrician, and there are no apparent problems so far, however, it is installed on the CU, RCD and upstream with a RCCB with no MCB,
I’m just not 100% sure if it’s the safest way to install it, I would personally think that would be safer on an RCBO or on a MCB, I’m not worried about overloading as it’s on a 10mm2 cable, 40a RCCB and the unit draws a max of 25Amp, I worry more about the fact that the RCCB will not protect on short circuit.
I appreciate any feedback or comments.
  • [ElectriciansForums.net] Induction hob correct install
Can't be certain but it appears the RCCB is fed from the top left 32 amp MCB.
That board is a bit of mess to say the least.
Thanks for the comment, yes not state of the art.. it’s a 20 years old CU. The RCCB is feed from the busbar from the RCD as all the other MCBs on the busbar, I think there is no problem there. Question is about the RCCB being safe or not without an MCB.
that whole board is a complete disaster. wants scrappingand a decent new board installing. don't use the same electrician. seen better jobs done DIY at a Gypsy site.
In that case, the circuit fed from the RCCB has no overcurrent protection.
Reply to Induction hob correct install in the UK Electrical Forum area at ElectriciansForums.net
