Info | on ElectriciansForums
Discuss Info in the The Welcome Forum area at ElectriciansForums.net
cumbria
Hi to all and looking forward to asking and reading your comments on various tasks. My question is when can you start to sign off your own work.
Looking forward to you reply
You can sign your work off when you're competent to do so.
You can sign off when you are competent to do so also if the work you are doing falls under part p then you will have to be a member of a scheme (niceic, napit, elecsa) to be able to sign that work off
If you have the necessary skills and experience to be able to carry out the job you are doing competently and safely then you can sign off that work on a suitbale installation certificate.
BS7671 3rd amendment is planned to have the following definitions:
Skilled person (electrically). Person with relevant education and experience to enable him or her to perceive risks and to avoid hazards which electricity can create.
Instructed person (electrically). Person adequately advised or supervised by electrically skilled persons to
Ordinary person. Person who is neither a skilled person nor an instructed person
The Electrically skilled person would be the only one expected to complete certificates.
To define competence is difficult as it cannot be precise.
Competence can be aided by qualifications and by experience and also requires the person involved to be confident of that competence.
If you have been appropriately trained, by whatever method, to be able to undertake the work you are doing in a workmanlike manner, and inspect and test, and be able to assess and interpret the results of this inspection and testing in comparison to the requirements of the wiring regulations (and the building regulations, and the EAWR, and HSAW Act, and...., etc.) and confirm that the installation is compliant and safe then you can complete and sign off the certificate.
However competence can only practically be determined in retrospect, once the court has failed to convict you!
When your brain has absorbed 3-4 years knowlege and you have the tools to do so.
Hi Murdock ,sorry I should have put in my first post I have City and Guilds Level 2 all modules
City and Guilds Level 3 all modules and 17th Edition and done part time in a paper mill with there
electricians.
electricians.
Are you looking at domestic or industrial?
Reply to Info in the The Welcome Forum area at ElectriciansForums.net
A
Welcome to the forum - dont forget to log in next time! We love pics of projects if you have any
Great stuff - thanks for posting
