Infra Red radiators, or........
My final comment - the OP seems to be expecting to install a cheap system, expecting it to be cheap to run.
An expensive system to install is only expensive once, an expensive system to run is always going to be expensive.
Exactly. But, the fear of an expensive to run system "Could" be based on all of our previous experience/baggage. The electric technology is racing forward at present. I'm exploring all available directions.
I'm not sure that electric heating technology is really racing forwards, resistive heating elements are as close as you'll get to a 100% efficient means of converting electrical energy into heat energy.
There are an awful lot of manufacturers claiming to have re-invented this particular wheel at the moment, I don't think any of them really have though!
House is not that big! Unfortunately.
CU is a MK Sentry 21 way, or similar.
Supply is not an issue. As stated in o.p.
I will be have normal rungs up n down.
Heating rings up n down.
Kitchen ring. Utility room ring.
Radial for outside sockets and possible garden lights. Radials as required for immersion heaters. Radial for shower in downstairs cloak/wetroom.
Air pump is a consideration, but the wet rads temp is considerably lower than a conventional boiler. Might consider air for the immersion heaters though. Ground pumps is a no, as stated in o.p.
How can you know what size CU your electrician will fit if you don't even know what heating method you will use and therefore the number of circuits required?
Why are you intent on installing ring circuits for the heating? This is a very poor installation design.
I expect he's already bought it!
The electric heating idea has only come along in the past month.
If I do go that way, why would it be a bad idea to have a separate ring? Such a load of 11kw, for several hours, on a circuit using other stuff too? Surely safer on its own ring?
Remember, there is no wiring at present, the previous wiring is ripped out, and it was all in the wrong place anyway. Nothing is chased out. The cables will be in conduit along the floor then hidden by the selotex/boards/laminate, upstairs the conduit will be chased out of the 70mm of screed on the concrete floor. I can have as many circuits as feasible, allowing for future expansion. The only extra cost is the pennies for cabling and the extra RCBO (Or whatever as necessary) in the CU. Sparky will be wanting 7-8k for the job, adding the odd £50 is nothing.
The price difference between a 11 way and 21 way CU is also lost in the noise.
Hence, as per my OP........I need real reports, not the "Frequently asked questions" of the websites selling the kit.
I had three CU's in my shed, all now illegal and binned.
I will be getting the MK 21 way. It leaves room for expansion. The location of it is a brick built cupboard 1 metre wide so that isn't an issue either.
QUOTE]
A ring final circuit has been designed for socket outlets, not fixed appliances like your proposed heaters. It is not intend to connect such loads, and appendix 15 BS7671 recommends loads of over 2 kW, should have their own dedicated radial circuit.
It's good to know my logic thinking is in alignment with the law. Cheers.
A better design is to have a radial circuit for each heater, or each small logical group of heaters, e.g. Bedroom and associated ensuite on one circuit. The ring circuit was not designed for supplying fixed heavy long duration loads such as heaters, the advantages of a ring over radial circuit are lost when it supplies only fixed loads.
Individual circuits also result in much less disruption under fault conditions and can allow for simpler control wiring or more options for fixed overall control.
Oldshape,
Oldshape,
