Hi - In theory, increasing the input water temp will mean the output water can be hotter for the same flow and power, or any combination of these depending on the heater controller’s capability. However, as has been said at some point it might just trigger the unit’s thermal protection and shut it down. If you can advise the make / model we might be able to be more specific.
This one lists max input water temp as 28C, for example.
We don't have a gas boiler so I can't guarantee there will be sufficient hot water available 100% of the time, especially using solar.Can i ask why you are not using the mains fed HW for a mixer shower set-up?
Thanks Wilko. My plumber has a mixing valve that he uses for residential homes that is locked at 55 deg C. It is adjustable downwards & hopefully we can get it set to around 20/25 deg C. I expect this valve would not be affected by variations in flow as it is constantly adjusting to the conditions at the time. This lukewarm feed setup could also be used for other cold feed appliances such as dishwashers & washing machines. If you have excess hot water either from solar, gas or solid fuel then you could probably save money on these appliances too.Hi - here’s the Triton T80 spec, if that’s your unit. It shows 28 C as the maximum input water temperature on page 4.
https://www.tlc-direct.co.uk/Technical/DataSheets/Triton/T80Z_FF_Instructions.pdf
Just to say - I’ve not seen this done before.
The mixer will be key to keeping within the shower manufacturers specs. Perhaps confirm all flows and temps with power to the heater properly switched off.
Let us know how you get on![]()
I agree that the post relates to plumbing but thought that solar pv users with free hot water would be more likely to have tried, researched or considered this, so I posted in the solar pv forum.Jouleflow... it sounds like your 'energy storage tank' is a thermal store type solution, which is fantastic ! The idea with these is that they hold a large amount of water (water has a high 'specific heat capacity' so is ideal for this) that stores heat energy from a number of sources (log burners, solar pv and tubes, off peak grid etc etc.) that is then used for whatever it needs to be used for. The tank is designed to 'stratify', i.e. very hot at the top and cooler as you go down. Therefore, heat is taken out at the appropriate height depending for the temperature required. E.g. underfloor heating uses low temperatures, so it takes heat low down, but traditional wall hung radiators need high temps, so they should take heat higher up.
A coil of pipe inside is used to input or extract heat.
Therefore... what you want is 'technically' achievable as you just want to run your shower supply from a very low level in the thermal store, with some temperature control attached to it, so as not to have water >28°C
This is really a plumbing question rather than an electrical...
