Deleted member 26818
What point?same results only difference is rcd times. All im saying is does no one else think its a bit overkill to do the tests again. Regs are just a guide not an act
Discuss Install cert required if eicr has been done in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It all depends on whether you've been asked to replace a CU or to carry out a condition report....the result of which recommends a replacement CU.If you've already done a full EICR on the property, the only additional tests apart from identifying the new circuit layout would be the RCD tripping times. As you would have already recorded test results from your previous inspection
I understand what we are told to do. I know that. I just want someone to give me an explanation as to why?? Not because the regs say but why in theory and practise does it have to be done
Hold up, first it was just a CU change, now it’s also upgrading tails.When i have already asertained the installation safe and have made it safer by upgrading tails , adding mcbs and rcd protection
Why wouldn’t I, if all I am doing is changing the CU?Would u connect the old ( more than likely single insulation) tails back in?
Ahhh, does no one ever think why something is done instead of just doing what your told
Extremely unlikely, I'd say.Would u connect the old ( more than likely single insulation) tails back in?
Reply to Install cert required if eicr has been done in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
