Installation of SWA cable | Page 4 | on ElectriciansForums
Discuss Installation of SWA cable in the UK Electrical Forum area at ElectriciansForums.net
E
ElecEngineer
Can any one help..?
Having not installed any SWA before I’m about to undertake a job to install 6mm 2core cable to agarage. The cable would need to be buried for approx. 20m in the ground – whichI’m allowing to go 500mm deep. However it is when the cable first enters theground and when it comes out I’m concerned - remaining areas will be fixedevery 300mm onto concrete gravel boards etc – what mechanical protection would Ineed as it vertically enters and leaves the ground? To protect from strimmeretc.
Also I’m allowing for a IP65 rated garage consumer board withstandard sockets and switches - but are there any limiting factors ininstalling by windows and doors?
well maybe you should leave saying any thing because you refuse to answer any of my points
Some useful advice for you sonny ....... never EVER get involved in a pi$$ing contest with certain older hands on this forum. They have forgotten more than you're ever likely to know in your entire lifetime!
If you're not happy with the very sound advice you're being given then leave and try elsewhere.
THIS forum is for Electricians - with a capital "E" - NOT two bit chancers.
I think he does not have the BGB, or can"t read it, as for have not installed SWA before what did he learn at collage how to plum in a washing machine, as for RCD why not put one in the centre of SWA as well as both end as this would not help at all but might look good
But I think a better idea would be to just get some 2.5 twin/earth as it"s a lot easy to make off than SWA and then just IT it and put a sticker in flowerbed.
JOB DONE no need to test as it will be OOK in the end and we will not have to put up OPs like this,
Reply to Installation of SWA cable in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
