Installing an outdoor socket | Page 2 | on ElectriciansForums
Discuss Installing an outdoor socket in the Australia area at ElectriciansForums.net
J
Jelj360
Hello everybody,
Can anybody tell me if I need another RCD to protect a single outdoor socket in my garden?
I already have a 30mA RCD main switch at the C.U so would this be sufficient?
Also, would it be ok to spur straight from a socket on the ring circuit-using 2.5mm SWA to the socket, about 5 metres away or should I run it from a fused spur?
Any advice would be much appreciated!
Nobodys mention glanding the armour ,galve u box gland amour into there ,stuffing gland ,the 2.5 mm twin and earth to socket ,box seal lid ,gland other end , test ,notify , job done , oh and the cable has to be 600 mm deep
Reply to Installing an outdoor socket in the Australia area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
