Installing Downlights? | Page 2 | on ElectriciansForums
Discuss Installing Downlights? in the Australia area at ElectriciansForums.net
W
whazza22
Can anyone give some advice on installing downlights please.
Once all the holes are cut, do you lift floor boards above so you can get cables through joists?
http://www.esc.org.uk/pdfs/business-and-community/electrical-industry/BPG5_08.pdf
Table 1 page 9
check this out for best practice, thermal effects was the third rating I was thinking about not specifically fire rating.
It would seem though that all new builds are required to have fire rated d/lighters. Building inspectors have been known to request the replacement of non fire rated d/lighters (just installed) and it is probably going to become standard in the future as when you make holes in the ceilings you are reducing the fire rating of any ceiling.
I don't disagree with what Jason is saying but it would seem to be that fire rated d/lighters would become the standard in the future.
apparently the NICEIC are trying to clear this issue up.
Reply to Installing Downlights? in the Australia area at ElectriciansForums.net
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
