Installing Ring Doorbell Pro Using Plug in Transformer | on ElectriciansForums
Discuss Installing Ring Doorbell Pro Using Plug in Transformer in the The Welcome Forum area at ElectriciansForums.net
KAS
uk
Hi, I am asking for any advice on installing the ring doorbell pro. I am interested in installing it using a plug in transformer , as I have no existing hardwired doorbell and no space in my cu. I was wondering if anyone had installed the ring pro using this method (which you can do) and if so which uk plug in transformer did you use and could you point me in the right direction to purchase one as I am having difficulty finding one. Thank you in advance for any help.
What plug in transformer do you need.. eg. voltage and current.
How does the manual tell you to install it?
Think the pro includes transformer
Hi, thanks for replying. Yes it does but as I explained above it is for use in CU. I have no space in my CU for it, hence I am going to use a plug in transformer 24v AC 1.5 AMP, its just trying to find if anyone knows where I can buy in the UK and if anyone has used a plug in transformer to power their ring pro.
I can use one the same as a Dantech DA652, but I am finding it very difficult to source one. I was hoping that maybe someone in the forum may know of one similar that I could buy and where from in the UK. The DA652 is 24V AC 1.5A
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
You could pop it in a small DIN enclosure, screw it to the wall and connect up a flying lead with a plug on the end.
Where the flexible cable (cord) enters the enclosure it should be suitably restrained to prevent stress on terminations. Stick with the item Spoon suggested you are getting from Amazon.
Reply to Installing Ring Doorbell Pro Using Plug in Transformer in the The Welcome Forum area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
The light may have a permanent supply already inside it if you are lucky.
