Insulation Resistance of floodlights | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Insulation Resistance of floodlights in the UK Electrical Forum area at ElectriciansForums.net
Davetherave
I keep getting short circuit between live and earth. I can't work out wether this is normal or a genuine fault. Unfortunately I can't lower the floodlight to inspect further. Can only test at the bottom of the base. Can any one help?
0.14 ohms
Well if it's really 0.14 ohms L-E and the light works, the CPC must be O/C somewhere and there is a risk of exposed bits being live. If this is not obvious to you, I suggest studying a bit more about testing before undertaking this kind of work.
OK so you walked over to a random floodlight that was WORKING and thought hummmm im going to do an insulation resistance test on this working light????
WHY MATE ???
Alternatively if you are part of the electrical trainee Nerd Herd then leave the flood well alone and let it continue working normally as it is before you do F it up !!
Reply to Insulation Resistance of floodlights in the UK Electrical Forum area at ElectriciansForums.net
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
Recommended Sponsor News
Hi everyone,
