It's nice of of you to thank everyone . Not everyone has the courtesy or manners to bother.
Well done anyway.
Well done anyway.
Discuss Insulation resistance problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Whilst it is usually Mega for millions only Megohms is correct for referring to millions of Ohms (Megaohms is NOT correct).
Although the fault has been found, I am still a bit confused about the fact the OP split the ring and got the 0.00 reading on both legs, yet the OP only mentions one plaster board screw through one cable!!?? I can only assume that the OP connected the ring circuit back at the cu, then split it at the mid point, thus creating a radial??
Please correct me if I have read the other posts correctly, I have a bad hang over this morning, so I'm not totally compus mentus (not even sure this is the correct spelling)!!
Cheers
Jay
He could only have done what you've suggested, split the RFC at a socket and left the legs connected at the CU or Vicky-Vercky! If the RFC was disconnected at the CU the fault would of been isolated from the rest of the installation's other circuits?Although the fault has been found, I am still a bit confused about the fact the OP split the ring and got the 0.00 reading on both legs, yet the OP only mentions one plaster board screw through one cable!!?? I can only assume that the OP connected the ring circuit back at the cu, then split it at the mid point, thus creating a radial??
You monkey, like a dozy git I read through the entire thread not realizing I'd already posted in it and then only checked the date on the very last post!Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply.
It's okay. Part of the intention is to dig up some gems. As I don't know much about sparky stuff, I can only check stats for the threads and see what used to have a bit of traffic and doesn't now. Assuming it's just got lost a bit over time.You monkey, like a dozy git I read through the entire thread not realizing I'd already posted in it and then only checked the date on the very last post!
Reply to Insulation resistance problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
