E
Engineer54
Here's one for you... I've been going through submittal drawings for a staff canteen, i won't go into too much detail but the means of access to the service counter is via below a modular tiled raised floor system from the DB.
The part of the submittal that i'm going to refer to, is the two ring circuits for the power outlets on the service counter to supply the various hot and cold drinks, food heating and cooling appliances etc.
They are proposing a 3 core 6mm SWA to a wall JB and a FRC within counter stud construction to a surface mounted dado type PVC trunking system housing the socket outlets etc wired in 2.5mm 3 core building cable, connected to the SWA via that wall JB. The use of the SWA is to conform to the project specification of only mechanically protected cables being allowed below raised floor areas.
So what are the thoughts on this arrangement, i'd be interested to know what others may think here??
