Intermittent disturbance on Sunny Boy inverter | Page 2 | on ElectriciansForums
Discuss Intermittent disturbance on Sunny Boy inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi All
My 4000TL keeps cutting out with a grid disturbance every few days and the red fault light comes on.
When that happens, it does not reset but stays off and gives no output, sometimes all day.
I think the installers set it to GB settings because we checked it at the time of installation and it was in German or something (it does say English now) but I did notice that it also says C10/11.
I didn't notice it saying G83/1 so is it maybe set wrongly?
My Sunnybeam registers grid disturbances once or twice every day but it only cuts the inverter out evry few days.
I have emailed SMA support (thanks for the contact info further up the thread) but do you guys have any suggestions?
Cheers
Dave
I believe C10/11 is Belgium's settings. SMA inverters can be set to any country's setting yet be forced into English language. Sounds to me that this is what is happening.
Your installer will need to get the code. You won't be able to get one yourself as the end user.
Hi
The system was installed via my own company. My company purchased all the kit and the installers fitted it. I subcontracted the installers so effectively, I am the supplier/installer.
I take it I will definately need a code to change it?
Cheers
Dave
Yeah, if you've had the inverter operating for a while. You need to speak to SMA about applying for a Gridguard code. Takes a couple of days.
Then you'll need a laptop with bluetooth.
Hi
I emailed SMA and got GridGuard Code application form - filled it in and got the code yesterday. I got the inverter sorted today.
The email stated to use Sunny Data Control software but I couldn't get it to see/use the bluetooth adapter.
I then used the Sunny Explorer software and that worked fine. If I remember correctly, I clicked on Tools and selected GridGuard and that let me put the unlock code in. After a few seconds, the inverter clicked a bit then the green generating light went off.
After that, I clicked on the Settings tab, clicked the down arrow on the gridguard section and then clicked the edit button. Went to the country code bit and changed to G83/1 - It took the setting ok and a few minutes later the generating light came back on and all seems to be fine now.
Hopefully this bit of info may help somebody out.
Cheers Guys
Dave
Yeh i had this grid disturbance problem.Connected to sunny explorer entered grid guard code and changed the country settings to g83/1.
I think this is a very common problem and most pv installers especially when starting out after passing there mcs had to go back and change country settings on sma tl inverters due to incorrect 1st time commissioning.
Happy days were all still learning.
SOLUTION(Mine) - Sunnyboy 3800 Voltage Disturbances Vac-Srr - 263.9V present, 259.1V now. Should be 216-253 (230)V-6%+10%.
PV system trying to deliver 3.6 kWh.
Voltage at generation meter shows 257-260V.
Solution:-
1 - contacted SMA uk via online form with Serial no. also mentioned that Inverter in loft with 15m of 4mm twin and earth.
Reply from SMA :-
a - inverter set to UK settings at factory.
b - 4+4mm cable may be light (my calculations suggest 2.5V drop over 15m at peak current.
c - suggested I speak to distributer as voltage high on mains.
2 - Contacted Electricity North West at 4:30pm - Emma took notes.
Reported high voltage especially at mid day on sunny days.
a - asked if I was available until 8pm?!
...me - it's not that urgent?!
b - 8:15pm Pete arrived. Saw my readings agreed accurate as inverter similar.
c - Pete checked mains before mains meter. 253.7V.
d - powered down our PC'S etc. Power off and line impedance checked ok. Power up again.
e - Pete agreed Voltage high/too near max and would visit substation 200m away.
F - Village blacked out for 5 mins at 11:05pm. (Not my fault honest!) Possibly moved transformer to next tapping.
Me - 8am checked mains supply at generation meter... 243V when generating 1kW. Probably no need to upgrade the cable from the inverter just yet.
Well done Pete and Emma from enw.
Hope this helps someone else.
Thanks to the forum for pointing me in the right direction too.
Nev
Just
I find it disturbing that installers are installing SMA inverters without reading the installation manual. It is quite clear that the correct country standard and language setting should be checked before commissioning.
My teams are all trained to check this both physically when installing the inverter and on commissioning when the display first comes to life. It should state that it is set to English language and then G83/1.
just about to say same thing from the above posts it is clearly stated in the install instructions set country of origin codes
Hi all - new to the forum.
Retired Contractor in HVAC, Electrical, General.
I have 3 Sunny Boy Inverters in use, 2 of the 3000TL-US, and a 6000TL-US.
All of them show 127V-130V output on the display, despite being 220VAC.
An amp-draw shows correct amperage at 220VAC.
So now I'm perplexed - why does the display show one leg ?
You're probably reading the DC input....
Photos of the displays would help
Your original post at 2:20 am UK time (BST) suggests you were up late or that your location is correct e.g. California and your time was 6 or 7pm.
I would be interested to know why you are expecting to output at UK settings 230Vac rather than USA 120VAc.
Should we assume you are off grid with a UK fridge etc?
Last night i looked at a youtube video for your sms TL US series and it showed the 2 strings separately... whilst highlighting the each panel group graphic on the display.
As above a photo would help.
Your best bet is to contact SMA-America, the uk/German guys were great.
Contact - http://www.sma-america.com/home-systems/contact.html
Nev
Nev
It seems I didn't include enough info.
I'm in the US with 220VAC output from the Sunny Boy - all the dials are set to "0".
The unit is producing power as designed.
All the panels are on one string due to the voltage required (170VDC as I remember). If the panels were split, it wouldn't trigger on occasion.
The question is how to get the panel to show 220VAC output that it is producing.
I'm sure SOMETHING has been left out here ... LOL
Reply to Intermittent disturbance on Sunny Boy inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
